My 04 660 starts very hard in the cold and some times not at all. It does have an aftermarket CDI not sure what kind it is was in there when i bought it. Can any one help with this before i get stuck out in the cold.
Mine does the same thing. It too has an aftermarket CDI. I found that it starts a little easier if you reduce the spark gap. It's not the valves. I checked mine at 40 hours and it was fine.
The manual gives directions on how to use the choke. I read through it and it seemed to help.
Becareful, I was cranking on mine with the choke on and it wouldn't start. I turned the key off then back on and "KABOOM" One hell of a back fire. Apparently, each time you turn the key switch from off to on, it causes a spark. It is repeatable. Pull the plug and turn the key off and on. You should see it spark each time.
I'm told that the stock one works fine. However, I've seen my brothers do the same thing. Though not nearly as often as mine. His is the stock cdi.
