Replacing 4wd servo motor only vs. complete unit. How to with pics.
29K views 30 replies 8 participants last post by  oleblue22
#1 · (Edited)
Seems like alot of good info on this site. Long time reader first time poster. That being said I wanted to contribute a little to the site myself. I have found a motor that will replace the servo motor only on the Rhino 04-07 660's, 06-09 450's and the 08-11 700's. Beats the heck out of paying $200+ for a complete unit. Hope this helps.
This will work on Rhino's and all the following models
08-11 Rhino 700
06-09 Rhino 660
06-09 Rhino 450
02-08 Grizzly 660
07-11 450 Grizzly
09-11 Grizzly 550
03-06 Kodiak 450
07-11 Grizzly 700
08-11 Grizzly 450
07-11 Big Bear 400
04-06 Bruin 350
04-06 Kodiak 400
05-06 Big Bear 400
06-10 Wolverine 450
07-11 Grizzly 350
07-08 Grizzly 400
This first write up was an install on one yesterday and I took pics and wrote a how to. This write up applies to the following
08-11 Rhino 700
Keep scrolling down and I have another write up on the 660 Rhino and 450 as those motors are a little different.
This install was on a 08 Grizzly 700 but they should all be the same for the most part.
If you have a skid plate it would be easier to remove it to access the bottom bolt on the servo and also to let the oil drain. I also recommend having the bike in 2wd to ease in installing the servo back on the diff.
Here’s what it looks like in the bike.
This image has been resized. Click this bar to view the full image. The original image is sized 800x600.
Here’s what it looks like when the servo assembly is removed.
Remove the 3 10 mm bolts that hold the servo on the diff. Gear oil is going to pour out unless you drain it first.
Remove the six phillips head screws that hold the servo assembly together and it will look like this.
Take care not to turn the big black plastic gear. This will cause you problems and will be a headache trying to get everything back in time.
Once apart you’ll see the motor and the two small phillips screws holding it in. Don’t worry about moving the small white worm gear next to the motor to get the motor out. That won’t be a problem, just don’t turn anything on the other half of the case. Once the two screws are removed, carefully pry up on the motor to remove it.
Motor once removed. Old motor on left, new motor on right.
Put the new motor in and reinstall the holdown bracket with the two small phillips screws.
Put the two halve’s back together again making sure not to turn the black plastic gear. Reinstall on your bike, fill with gear oil and enjoy the money you saved vs buying a new servo.
If anyone has any questions or needs a motor please don’t hesitate to shoot me pm. Hope this helps.
The following is the write up and pics for the Rhino 04-07 660 and 06-09 450. Same motor basically just different shafts and no metal gear on these ones.
I pulled the complete diff out due to having to change a seal but you can do this with it still in the bike.
If you have a skid plate on you will have to remove it to access the bottom bolt on the servo. I also recommend having the bike in 2wd to ease in installing the servo back on the diff.
Remove the 3 bolts that hold the servo on the diff. Gear oil is going to pour out unless you drain it first.
Once removed from the diff. Remove the six T-25 tamper resistant tq screws that hold the servo together.
Once you get the screws out, carefully pry the servo apart taking extra care not to turn the gears inside.
Once apart it will look like this.
This image has been resized. Click this bar to view the full image. The original image is sized 600x800.
You can see the two screws that hold the little motor in.
Remove those two screws and carefully pry up on the motor and remove it and the small gear attached to the end of it.
Picture of the motor removed.
Once removed installation is the opposite. Just be sure not to turn anything inside the casing once you open it. The small worm gear on the motor doesn't matter just don't turn anything else.
#7 ·
Found more models that the motors fit. This pretty much has most yamaha atv models covered. If you find one that is not listed. I can try and find it for you.
04-06 Bruin 350
04-06 Kodiak 400
05-06 Big Bear 400
06-10 Wolverine 450
07-11 Grizzly 350
07-08 Grizzly 400
#11 ·
This post is great. Would like to get one or two of these motors, are you selling them or can you tell us where to get them. Thanks.
#17 ·
I'm having an issue in the front diff servo . When i push the button on the dash i hear what sounds like the motor trying to engage ,but it will not light up the diff lock on the dash. I was just looking for some direction. I didn't what to go pulling things apart that are not necessary ? P.S great contribution to forum on this topic , the pics and details are priceless. Doubt there is manual out there that can be down loaded that could be this help full to the do it your self er.
#18 ·
First you need to check and see if it's actually going in 4wd and diff lock. If it is, then you either have a problem in the wiring from your servo assembly to your display or a loose wire or connection at the display or servo. I would check all the plugs on the relays that operate the 4wd and diff lock and also all your plugs and wiring behind the display. See what happens when you do that.
If you are not actually engaging in 4wd, but you hear the motor trying to, I would pull the servo assembly off the diff and inspect the slide gear. Make sure you can move it with your finger. Shouldn't be alot of resistance on it. That will burn those little motors up in a minute if your slide gets stuck.
Maybe this will get you started in the right direction.
#19 ·
Can I get a PM with the source of these motors?
#27 ·
how much are the motors
