OMG!! am I ever glad i did a search instead of a new topic. this is exactly my problem as described by rutting rhino.
my son played with the linkage rod, which probably explains why I have problems. original issue was difficulty getting into low range. now I have a problem with reverse, and to ice the cake, low range is acting up again. harder to shift when I'm on an incline.
i noticed the metal shift lever bracket is kind of wimpy and twists easily. so my hand shifter seems to slide and appear to shift okay, but it doesn't have much effect on the final push to the engine's shifter arm. I basically see 3 sections: the hand shift lever, the adjustable linkage rod, and the final shift arm on the engine. the only adjustment seems to be the linkage rod with lock nuts on either end.
so how finicky are these to fine tune and get right? Is there anywhere else to look and try to get this right?
is it possible the shift lever bracket twists and contorts, adding to the difficulty? This bracket almost needs a gusset or something to stop it from moving.
thanks
