First of all, is it worth the upgrade over the standard kit? Is there a noticeable difference?
Greg, is there anyway you can post up the upgrade kits dimension and mounting point information? I need to make sure it would even fit my Rhino as it was built around the standard 6.5 XTR kit.
Lastly, I know it's not likely, but is there any chance I can get trade in credit for the Elkas currently on my Rhino?
yes big improvement. it corrects the shock angles, which lets them actually work.
true shock angle should be 90* to bottom arm at full bump, I don't think the tower kit is 90 but it's alot close that the stick location
sorry for the delay in responding , e mail me and i'll forward the info .it's on a pdf and quite a bit of info.
it will fit your rhino if you if your running the lsr xtr kit.
[email protected]
