What do you mean benzito HOLY MOLY the 450 is geared much lower than the 660 an for the type of riding we do in the moutains slow crawling around it does great. A friend of mine has a 660 with the same tires an he has a much harder time pulling these tires in the moutains then us 450 boys do.
Yes the 450 will turn them very well I run 27inch XTRs but have also broken both rear axles, but we ride ruff no (ROAD COWBOYS) here.
u guys r rhinonutssss
Where do yall ride in the sand or what? Because where we ride that light bar you have on top would be trashed real quick. A tree would take her right off. By the way that is a sweet ride.What do you mean benzito HOLY MOLY the 450 is geared much lower than the 660 an for the type of riding we do in the moutains slow crawling around it does great. A friend of mine has a 660 with the same tires an he has a much harder time pulling these tires in the moutains then us 450 boys do.
we just put ours in low and were gone.....
I ride in everything. Forest, Desert, Sand, snow, mud, rocks. You name it. If the light is coming off, my roof it coming off as well. It sit's below my roof.Where do yall ride in the sand or what? Because where we ride that light bar you have on top would be trashed real quick. A tree would take her right off. By the way that is a sweet ride.What do you mean benzito HOLY MOLY the 450 is geared much lower than the 660 an for the type of riding we do in the moutains slow crawling around it does great. A friend of mine has a 660 with the same tires an he has a much harder time pulling these tires in the moutains then us 450 boys do.
So I should be fine with 27" swamplites stock width on stock wheels. My 450 is stock other than cdi and I don't want to really do any mods. My rhino is for hunting and some trail riding. Also did u lift yours at all. Looking at CFM 2" for mine.27" XTR's and i spin them fine, i think that you could go even bigger with a lighter tire if you wanted
yes 27-9-12Cool so I'll check out the bighorns. U mean 27-9-12 all the way around.
