1 - 16 of 16 Posts
i have a 07 660 it is completely stock with 1600 miles, it starts easy,idles good, but once you take pedal past half throttle it begins to miss and then smoothers out. i checked fuel filter and it is staying full i didnt know if the plug will cause this prob. or what the deal is. all info is appreciated
Do you maybe have an issue with the slide or diaphram? Remove the top cap of your carb and inspect the rubber diaphram for holes or damage, also inspect the slide itself a good backfire can easily burn and damage it...
Nate
Alba Racing
check your sheave.
if the grease inside there is dirty and caked up its like being stuck in low gear.
mine was so bad i almost couldnt pull the cam plate out, stuff was like stale peanut butter.
afterwards install some greaseless rollers and slides and never worry about it again.
1 - 16 of 16 Posts
