1 - 20 of 35 Posts
Wondering what some of the higher miles on your rhinos are?
My 08 has 1,000 and our 04 that has been torn apart for two years and has just been brought to life again has 4,900
I got 3700 Hard dunning miles on my 06 .......it's got a lot of blow by and uses oil. I've burnt up a couple of belts. and busted 3 steering wheels. had the front diff issue....
My son may be going in the army in the fall so I'm trying to get through the summer before I tear it down.
1600 on my 08 700. about 100 miles ago I pulled the clutch apart from some mods and my belt still looked brand new.
No issues so far at all with the Rhino.
6000 Miles on mine all high speed dunes and desert.
about 1900 miles on my 08. runs like the day i bought it. i also inspected belt and sheave looks great. my 05 had about 1500 miles on it when i rebult it but it overheated all the time.
3700 easy miles - still runs like new:banana:
4000 miles (6500km) on my 08, mid way I put in a different sheeve and nothing else needed and currently, the belt is starting to loose width (really I should change it) but all else is great.
1500 miles on my 08', also checked the belt and clutch and looked brand new.. no problems yet :fingersx: and i drive it like i stole it!
2700 miles on our 07. Did the stroker and Bronco clutch at 1500 miles thanks to a rod and crank bearing failure due to oiling issues of the standard rhino persuasion. You name it, dunes, rough trails, city streets, in the water etc... I am on belt #3 ready for #4 (dont move your boat in the heat )
My 07 660
has 1400 on it...bought it used in Feb 09 with 740 on it...machine is not pampered but maintained regularly....have new V belt ordered.....
Discussion Starter · #17 ·
Forgot to mention. The 04 had the dash computer put on about 6 months and 1000-1500 miles after we bought it, so it actually is over 6k miles.
over 3000 miles. Maybe 500+ snow plowing. 08 700. Running great, no problems.
Had the clutch serviced around 1500+ I think, and it was perfect.
how often you guys changing your oil. i was changing mine every 3 or 4 hundred miles. now im gona wate till about 600+.
I change mine every 1000KM (600miles) and i have 3800km on my Rhino.
1 - 20 of 35 Posts
