2011 Rhino 700
All,
I need to replace the right rear knuckle on my 2011 Rhino 700. The part number is 5B4-F532F-00-00. I've struck out with all the normal sources. Does anyone know of a place to get a new one?
I shudder to suggest this, but is it possible one of the Rhino clones out there would have knuckles that are interchangeable with the Rhino?
Thanks,
All,
Thanks,
Unless the body is damaged, I took to mine to a local parts house and they pressed new bearings in. I think it was around $65. I think that was about half what the whole replacement was.
2011 Rhino 700
I appreciate the advice. In my case, the axle nut loosened up (my fault), allowing the wheel to get a wobble, causing the rotor to grind a groove into the knuckle. It's probably not enough damage that I'd have to replace the knuckle, but since I was replacing bearings, rotor, hub, and axle, I figured I might as well do the knuckle, too, and not have to worry about any more repairs for quite a while.
