Does anyone know what the lug-nut torque should be for a 1" wheel spacer with tapered nuts?
Is it the same as our wheel lug nuts (40 ft-lbs)?
Should I be using thread locker as well?
Vendor
You can use thread locker on the oem studs to hold the spacer on the hub but I wouldn't run it on the studs on the spacer to hold the wheel on. Same torque specs as the oem studs.
Sent from my T-Mobile G2 using Tapatalk
Vendor
Perfect. After you put everything on ride around the block and retorque lugs just to be safe.
Unless your spacers have countersunk holes, I wouldn't run tapered nuts. I just learned this the hard way! I've also been told to run anti-seize lube on the studs holding the wheel on.
Thanks trucknuts, the spacers do have countersunk holes that match the tapered nuts.
I did have anti-sieze on the OEM studs, and will be doing this for the spacer studs as well. I always thought you were supposed to do that for wheel studs anyways.
