1 - 20 of 99 Posts
What about a slightly modified motor in a 4 seater?
7 or 8 paddle?
And what are you guys running up front?
u can play with psi in the paddles to get more wheel spin or more traction , less psi = more traction , higher psi gives u more wheel spin so if u do buy paddles that bite to much air them up ,
up front alot run buffs or the itp dual ribbed
the only reason i dont say doonz is there to much tire for a rhino, unless over 55hp, lol
also if u run doonz better make sure there on a 10'' wide wheel or ur side walls will blow out soon trust me, lol
Depends on your finances & weight
A heavy Rhino needs floatation. I had Scats and loved them but they dig and throw lots of sand needlessly. I could climb China Wall, Lizard, Brawley slide when most Rhinos can't. However, the tire that floats the best, throws less sand, rides smoother and yes climbs as good or better than the Scats is the STU sand tires unlimited 26"s with the # 1 paddle.(SandBlasters) Stagger cut them if you have a mild engine and are a dunner.. Little 686's can climb Brawley Slide with these with stock suspension and a bed delete. It takes less HP to push a Rhino when you are floating with a LONG FOOT PRINT. It is not the width but the length of the foot print that floats you. The Dunes are not flexible like the Scats and Stu's. They dig in and not float. No body bitches about following a Side by Side with STU,s. If you have Scats, get in the back and do your friends a favor. However, because of the $$$ and the fact that most guys have never seen or tried the Sandblasters they favor their Scats. NO, I AM NOT A SALESMAN FROM FULLERTON TIRES. but I have been dunning for over 40 years and have had over 20 sets of paddle tires. Nothing is better on the market as of now. Front tires is another subject of various opinions.
Dont listen to this clown - he comes out to the dunes and doesn't even bring out anything to ride! LOL :fart:
He is right about the best and also recommended sand combo. 7 paddle stock and modified, could possible get away with an 8 paddle aired down and tuff buffs in the front!
The Doonz also do well but the difference between the both is the Doonz are formed and the skats - the paddles are added to basic buffs. Either of well do well in the sand.
1 - 20 of 99 Posts
