1 - 2 of 2 Posts
Just acquired a used rhino that has the stock suspension with WER's. They have the adjustment knob on the top. Is it turn to the right for stiffer and left for softer or visa versa?
Thanks
This knob is for the low speed compression adjustment .... it will help prevent body roll on the corners .... it will not stiffen up your ride .... you will have to have them revalved for that ..... or you can use the spring adjustment for the ride height ....
If you turn the knob clock wise then it will tighten up the body roll .... counter clockwise will loosen it up ....
A good place to start is to turn the knob all the way counter clockwise then turn the rears at 8 clicks and the fronts at 6 clicks ...... that will get you started .....
1 - 2 of 2 Posts
