I tried a few different things that just didn't work out. Until I found this from summit racing. It is alittle pricey but it works very well. There are three sizes you can buy. I bought the larges sheet and it was enough to do mine and a friends cover.
I wiped down the inside with carb/brake cleaner to remove any oil. I made temples out of sheets of paper, taping them together and cutting to fit. Then tracing the templet onto it. I used some good tin snips to cut it. I did this in three pieces. After it was on I took a ball peen hammer using the rounded end to form it into all the nooks and crannies. I used some aluminum tape to cover all seams.
There is still the noise from the intake but it is so much quieter then before. I can talk to who ever without yelling. The cover gets warm but no longer gets hot. Check out the link below to summit.
DEI Floor and Tunnel Shields - SummitRacing.com
