I am new to the group. How many volts should I be getting out of my voltage regulator I got 5.6v 2009 rhino 700
Not sure about regulator, what problems are you experiencing? Voltage to the battery should be around 14.2
I tested the output on the regulator going to the battery only getting 5.6v my battery died before I could check stator for voltage output
Try charging your battery and checking from the stator, or switch your meter to ohms and look for a short to ground from the stator wires
