So I am working on a 2007 Rhino 660 sport. It is cutting out at high RPM's going up hill, backfiring and ultimately stalling with an extended crank time for restart. I was going to order a fuel pump / carb combo. I also noticed a small crack in the vacuum line coming from the air box and running to the crankcase assembly. I can't find any info about the sizing of the vacuum lines on this.
Does any sort of kit exist to replace all vacuum lines or does anyone know which ones I should be chasing down for this problem specifically?
Thanks!
Thanks!
