Primary clutch 175
Secondary clutch 125
Trans gears 65
Middle drive gear and bracket 40
Oil pump 25
Crank needs rod 30
Wet clutch 35
Through shaft 40
Clutch plastic housing 40
Stock rims 25 each
Cases 550
Head 425
Cylinder 75
Piston stock 35
Clutch belts 20
I also have tons of other boxes full of bolts nuts and other small things from part out let me know if u need something tiny I'll probaly have it can text if u want (270)871-2942
Tie rods or steering rack?
Where are you located?
