I still don't see how wiring the fan to always run could affect the high temperature at all!
I mean, if the engine hits 170, the fan turns on anyway. At that point, it doesn't matter if the fan is wired on all the time since it will be on either way above 170.
Wiring it full time may slow the time down to reach 170 a bit, but how can it keep the engine from overheating since it already turns on above 170 everytime??????
I hear you Rob...
I think the same way...
However, you can't argue with success and KMS is telling guys to do exactly that...they do it...and it seems to work for them...
I don't know...personally, I never even considered it...I am taking a completely different approach...
Having a light come on/off when the fan is supposed to be on/off does at least let you know if your thermoswitch is applying voltage to the fan or not...
Having a by-pass switch allows you to apply voltage to the fan in the event the thermoswitch is stuck open...it will also prevent that obscure ckt brkr that has been known to wreak havic from stopping you from having a cooling fan when it is supposed to be on...
As for why the 'KMS FIX' works or if it even works like guys claim I don't know...but, I would assume your guess about it getting a "head start" is the only one that would make sense...
Once upon a time...I had a Chevy truck that the fan clutch went out on...it was expensive...I was broke...so I put a direct drive on it...never came close to running hot again...
In the winter time...here in Chandler...I had to put cardbord in front of the radiator to warm up enough to drive without the choke on...so Yes...it does keep it wayyy cooler wayyy longer...
I guess the opposite side of your arguement is that if did not have a fan at all it wouldn't matter because it's gonna get hot anyway...and we both know the fan does make a huge difference...if it didn't...it would never shut-off...
I still view it as a desperate manuever...
