OK, I have decided not to sell my Rhino and buy other garbage, I'm keeping the money pit. However, I believe I should take it apart and replace the middle drive gear support as well as the one-way bearing. It has over 6500 miles on it. It does burn a bit of oil and from reading on here, a new oil pump would be a wise decision. I think some will tell me I should replace the piston and rings; I need to know where is a fair place to get the piston and rings. I am not looking for extreme performance, we just do regular trail driving.
I will also install the rear diff bracket, since my frame has already cracked the 2 ears and rewelded in the past. I'm also putting in an electric fuel pump.
Anything else that is reasonable to replace?
