Well I am getting ready to start fine tuning my 800 Rotax and have been reading up on tuning these gassers since I am used to working on diesel that you can run lean without worries.
This is what I have found so far for target AFR
Your target AFR should be around 14.7:1 in vacuum, around 12.5:1 at static, and around 11.5-11.0:1 as you approach your peak boost level. This will achieve the best fuel economy while supporting for lots of airflow
Does everyone agree with this? Thanks Adam
