Has anyone else had trouble keeping the bed latched down? This is 06 660. I have had to strap them down.
check your rubber dampers on the frame and under the bed.if they are worn or gone then it allows the bed to flex and will cause the latch to let go sometimes.
  • Like
Reactions: Brian Lee Rhino450
Holiday Winner!
Also check to make sure it is hooked all the way, I have had that issue, where I drive over a bumpy section of trail and look back to find the bed in the dump position. When you close the bed again, look underneath, try giving the catch a push to be sure it is seated all the way. I never have that issue when I do.
