Replacing both rear axles on my 07 rhino 660. Figured I would replace the oil seals rather than have a leak and redo it all again. Problem is I cannot get the seals out. I have tried prying from the back side with screw driver, and small prybar, tried pulling with a pair of pliers, tried scoring the inside of outside lip with blade to break the seal, I even tried little bite of propane torch to heat up n shrink it a little bit! I don't want to scratch/score I side journal of differential, and have leaks, but I need to remove it. Any helpful ideas suggestions??????
Discussion Starter · #2 ·
Well after messing with it for like 2 hours I finally got it. Tugging, pulling and prying. I ended up totally destroying the internal seal on the old one, but oh well. It was a pain. Job complete.
