1 - 20 of 29 Posts
I'm new to the forum and I want to thank you guys for allowing me to join....
I'm sure this topic has been covered, I've read alot of threads on hear about transmissions on hear but I want to ask this any way.......
I'm looking at buying a second rhino... It's a 06.... The problem it has is this....
When it's in gear ( 2 or 4wd) and you mash the throttle pedal it moves about a foot and then just rolls back.....
Is this an out put shaft issue...
A transmission problem......
A differential issue ....
That dont sound good, any clanking or grinding
Hopefully its not the middle drive gear
i would checkout the driveshaft first make sure the splines are good on ends. And the boss’s they go into
Discussion Starter #7
I hope to have a lot more info tomorrow afternoon....
I'm going to try my best to explore all that has been suggested to me
Pretty sure to check that middle drive gear just put it in neuteral and roll it to see if front driveshaft yoke turns like the rear driveshaft
Discussion Starter #10
If the front u joint turns and the rear u joint turns when it's in neutral then the middle drive gear is ok?
Should b. You can do one other check to b 100%, take belt off then put it in gear and push it. The secondary sheave should turn, if it doesent then its the middle drive gear. If it does turn then my thinking is its in the driveshaft splines or the boss’s like i said before
If it were mine and both shafts turned like they r suppose to i wouldent even do the second check i mentioned
Discussion Starter #12
Ok guys I've got new Intel on this transmission issue.....
I checked to see if front and rear drive shaft turn when unit is in neutral and pushed forwards and backwards..... They do.....
I wasnt about to look at the clutch sheaves....
When I started it up and tested it again there is a very bad grinding noise in the transmission.....
Check ur oneway bearing. Take the cage off the primary have it in neuteral and the primary should turn counter clockwise and not b able to turn clockwise
If it turns both ways its bad, they have been know to make some serious racket
Only buy an oem bearing donot go cheap on that part or u will b doing the job twice. On my 700 oem oneway was 186bucks
1 - 20 of 29 Posts
