looking for some help here. i have a 2009 700 rhino with a MSD programmer and it only does 45KM to the pin. The rev limiter seems to be stopping it. I have bigger tires (swamp Lights 26") so i put a new belt and daltin heavier spring to Compensate for them and still only 45km. Im so confused to what would be the problem. any help would be greatly appreciated!
Do you know what map your MSD is set at and what speeds were you seeing before the MSD?
You're not going to gain a lot with the MSD alone.
Found the problem lol kinda embarrassing but here it goes the primary clutch was really dirty almost jammed packed ! Also the battery box was full if of dirt cleaned both and worked perfect!
