Bought a used Rhino ,,06,,660 Previous owner. Informed me that it needed some work.. He had head gasket changed. BUT ,Mech did not change valve seals, Hence it smoked a little bit.
Not a game changer, Also needed a new belt. Still not a problem. Realizing it was not a new unit. Oil was still milky. Last winter ,I was recuperating from surgery. This spring ,I started working on it, You might have already guessed.. The more I work, the deeper it gets.Ran like it was out of time. Thought the mech may have let chain slip while doing cam removal, Lined up all marks and ,cam was off about a tooth. Replaced head gasket again,installed new valve seals, Changed oil.. Kitted Carb. ,new belt, new air cleaner. All back together. Torqued to spec's.. Fired it off n. Idles great, did not want to rev up, Same prob as when I bought it. Checked fuel delivery, Pump working good lines full, Was checking oil, and left oil dip stick loose \screwed in half turn. It blew out and big oil mist from blowby in crankcase. Oil is still clear, Check compression is 40 lb/s. Looks like compression is all in crankcase. Does not want to back up. Kind of humps up like brakes are locked. They are not locked.. Anyone want to try their hand at this problem child??
