What kind of tops do you guys have on your cages and what is the best way to fasten it. I took my to get a custom top put on my four seater cage and the guy wants to use canvus and snaps. I wanted to have wrap it around the cage and velco to it's self. He told me it will be to loose and it won't work good. I think that would look cleaner then using snaps. He wants to charge me $300.00 bucks is that too much? Any input would be helpful thanks.:1zhelp:
reasonable if he does a sweet job! And I would use HD snaps hidden so that you wrap top first, then loops under and around and snaps so you don't see snaps. Velcro will eventually turn that $300 top into a worthles, doesn't stick anymore top. And may fly off while cruising once it breaks in a lil. I used aluminum in mine and bolted it to tabs...
Sounds like a decent price, I bought mine for $250 2 years ago. I have the velcro and mine will definetly fly off on the highway. I have a buddy that has the snaps and that thing doesn't go anywhere and it always stays tight.
I'm in So Cal where is the shop at?
