1 - 8 of 8 Posts
Ok so here's the deal. Made the mistake of trying to turbo my rhino, but the damn thing is impossible to tune and unreliable. I studded the head, bored 686 9:1 or 9.5:1 compression piston, and not sure what cam i used, upgraded cooling system, running fcr carb, and dragonfire snowmobile clutch. I'm taking the turbo off and going to tear into the top end to change the piston and/or cam. I'm sure the topic has been discussed much but i dont have the time to search the threads. What kind of piston and what ratio on pump gas would be reliable yet give the power i want? and what exhaust should i pair it with?
thanks, chris
Administrator
Sorry to hear of your setback Chris ....seems the majority of Rhino engines that perform well are built NA designs, and not turbo or supercharged ...
And a heads up, you may be having a few peeps recommending a Rotax swap for your Rhino ....
sent from my broken Droid
thanks, chris
It is a mistake to put a turbo on a carbed 1 cyl motor...
Infinitely easier to do with fuel injection...
Are you going to remove the turbo...???
If so... you can go with 11:1 piston... a ported head with +1 valves and a big cam...
AZCourt just sold a motor that THE ONE put in his rhino and it dynoed at 56 rwhp... I believe that was a benchmark 693 ported with +1 valves ...
Not sure what carb is on it...
If you are going to keep the turbo you probably want to go to 8:1 on the piston...use race gas...with stock head and cam...and get an a/f gauge if you don't already have one..
You need an 11:1 CP piston kit with our DLC piston pin upgrade. For exhaust, I recommend either a Ron Woods Racing or the Muzzys. Both are great overall, there are pluses and minuses for each. We sell all of this stuff obviously, give us a call at the shop. 760-484-0986.
I'm getting away from turbos, too much hassle.
I have read different things on the cp 11.1 Some say use race gas, some say pump gas is ok. what is the overall verdict?
I have the head ported, what cam and valve setup would give me the best preformance/reliability with the cp piston?
Also any recommendations on a cdi? It is a 2006 rhino
Benchmark did my work and I've been running an 11:1 piston for a year now without any problems on pump gas.
Cam depends on how you use the Rhino. If you call us to discuss it, we can advise you.
For the CDI, a standard Dynatek is all you need. You might even find a used one. We just sold a used Dynatek yesterday.
1 - 8 of 8 Posts
