61 - 77 of 77 Posts
Sti black diamond xtr tires-27x9x12...27.8lbs
Moose 393 12"x7" wheels 10.6lbs
Together 38.4lbs
Just got these haven't got to install them yet since my rhinos gettng some warrenty work but they look great
Does anyone know how much the Doonz rear paddle tires weigh? what would be the best tire for a 4 seater rhino with ron woods and bolt ons?
Thanks bud, i am going to try the Doonz this time because of price. Glad to hear they do good.
Moderator
So i have itp mud lite xtr 27x11x14 on my 660 stock rhino.. I'am gonna be ok to ride at glamis or do i have to downsize tires?? thanks
You would have alot more fun if downsized your tires, and run 7 lbs of air all the way around. I would borrow some tires if you could...even if they were not in the best shape. If you dont go to the dune that often dont worry about it, but if your going to start going you might want to get differant tires.
yes. paddles allow you get up on top of the sand and "float" instead of digging in like an aired down knobby. you will be able to climb a LOT better and go more places
Doonz paddles on .160 12X10 real beadlocks. 26lbs 10oz for one. 27lbs 2 ozs on the other. Thats some real tight manufacturing tolerances there.
Super Moderator
Got some new rims and tires
STI HD Beadlock 12x7" 5+2 rims are 14 lb each
Artrax CTX Radial Tire 26x9x12 are approximately 21 lbs each. 6 Ply
Stock Viking rims and tires
Rear rim is 25x7.5x12
Front rim is 25x6x12
Rear tire is 25x10x12 Maxxis Bighorn 4 ply
Front tire is 25x8x12 Maxxis Bighorn 2 ply
Non OEM Maxxis Bighorns are 6 ply, only OEM skimp for cost and weight
Rear stock tire\rim combo weight ~31-32 lbs
Front stock tire\rim combo weight ~27-28 lbs
My new STI\Artrax wheel setup is ~35-36 lbs, an increase of 3-5 lbs on the rear and 7-9 lbs on the front. I will avoid doing high speeds in 4WD mode.
Stock Viking rear outside tire-to-tire width is 62"
Stock Viking front outside tire-to-tire width 60"
With my new setup, 26x9x12 tires on 12x7 rims with 5+2 offset on all 4 corners:
My rear outside tire-to-tire width is stock at 62" (Stock 10" down to 9" tire)
My front outside tire-to-tire width increased to ~63" (Stock 8" up to 9" tire)
The increased front track should help stability albeit looking weird being wider than the rear.
With HW machined sheave, slugged wet clutch, purple spring, 14 gr weights, and .3 mm shim and stock 25" tires I was barely hitting rev limiter at max 55-56 mph (hit rev going downhill).
Going to 26" heavier tires I'll have to GPS to ascertain my top speed, but the in-town radar showed me 2 mph slower than what speedo showed. I'm betting my speedo is accurate now (I wonder if the Wolverine and Viking have the same speed calculations despite the Wolverine coming stock with 26" tires vs Vikings 25" tires).
I will probably increase shim to .5 or .8 mm to compensate. My only other concern is that I'm no longer 62" compliant, slight front lift bring it back into spec? The Artrax tires are radial construction and actually have more surface area than my stock 10" wide tires as the contact patch is flat and the lugs are bigger/closer together as well.
61 - 77 of 77 Posts
