1 - 20 of 25 Posts
Need to know want is the best way to keep the front tires on the rim? When we are out mud ridding and if I don't hit a mud hole just write the tire will pop right off the rim. It really gets old also everytime that I pull through a mud hole and goose it the tire comes off again and I really need to know what the best way to keep the thing on. THANKS!
someone will say ....bead locks just to be a ass....but thats right...and why they where invented.....what psi are you running?...is it allways the same rim/side?
what tires do you have james and what is max on sidewall?....my itp's mud lits say max 7 psi on side wall...so thats what i run and all for
PSI?
Just need some advise because getting ready to go back to west virigina and really don't need this to happen on the hatfield trails. If I hit a whole on the side of the rim and will pop off everytime!
What rim are you running?
hey gator ...just a thought i had this morning....is it possable that you have 1 or more slow leaks?...so if the psi is right at your house and buy the time you get out on the trails you have lost some air?....especialy? if you loose your bead alot in a mud hole sounds like a good chance for a dirty bead...and slow leak.....if you have them all even at the house and let it sit....any loose air?
i just put 16 oz of slime in each of mine and bumped em all up to 12 psi from 7....just to make sure/help....also bought a nice slime brand tire plug kit while i was at lowes and some expanded metal for my radiator guard/shield....that store is rhino heaven!
Discussion Starter · #15 ·
Thanks Guys,
And I forgot to tell you were in W.V( LOGAN COUNTY). Guys thanks for all the advice but I have tryed all that and the tire still pops off the front side bend. The rim I'm runing is a ITP with 5 odd round holes in it ( IT CAME ON THE RHINO WHEN I BOUGHT IT) and it is just the front ones that do it.
Discussion Starter · #16 ·
Ralph,
tried want you were saying buy pumping them up and spraying around the bend and there are know leaks, also I take a compressor with me every time I ride and the proper air is in them all the time.
Gator...its hard to say... now...but i'd bet that the ITP wheels are made in china?...and the ITP Tires are made in china like everything else?....maybe you got a bad tire or wheel or both?....try and find a new set from someone to borrow..like james HR...sence you are going to wv to hatfield....if other wheels work good?...then you know?...
Thanks Guys,
What size(width) are the front rims?
1 - 20 of 25 Posts
