My temperature gauge light on the digital dash stays on even when started cold. The thermofan switch works fine and the fan comes on when the motor reaches temperature. I original thought it was the sending unit and replaced it. I checked both the new and old sending units with an ohm meter and both sending units are good. When the wire that attaches to the sending unit is grounded the dash light goes out. I have checked all the wires and I'm at my wits end to get this light on the dash turned off. Any help on where else to look would be greatly appreciated.
That is strange...
Are you saying you get good ground from the sender terminal with the ohm meter with the wire disconnected...
And that grounding the wire turns the light off (as it should)....
And that when you put the wire back on the sender it won't shut off...
If that is the case...I think you are either not getting as good a ground through the body of the sender as you think...or the connector is not making solid connection...
I would cut the oem connector off and use the bare wire to verify the system works with a good connection...then crimp a lug on and put a nut(s) on the stud...
Or you can just ground the wire....
I would highly recommend a gauge...
Gaffrig Marine full sweep electric is the best for a rhino imo...
