Hello everyone
I’m new here and looking for some help. I have. 2006 rhino 660 that has the hight temp light on even when first starting after sitting days. I checked all wiring from the sender by the water outlet to the dash- all is good. If I ground the wire at the sender the light goes off. By looking at the wiring diagram the sensor should be closed unless over heating so I should have ground until it over heats. If ordered 2 different senders- one for s gauge and one for a light. Both ohm out the same and neither fix’s the problem. Had anyone had this before or know if I’m reading the wiring diagram correctly Thanks Dave
