the suspension is loose on the drivers side in the back. it seems a lot looser than the other side. if i adjust the suspension will it fix that?? or is it possibly broken?
Define 'loose' - like that side bounces way more? The stock shocks blow (non reservoir) so if it's shot, you might as well upgrade to Progressive 525's or some sport reservoir ones (about $500 for either).
when I am driving, when you go over bumps and such it leans hard to the left in the rear. would that just need to be tightened? it doesn't feel like it is shot..
If it's leaning considerably then there's two things to consider. One, it could be a broken spring or mount. Two, it could be worn out.
Check over the mounts and shock holes.
Might be time to get some new shocks.
