These are from a 07 middle gear went out
Stator-75
oil pump-35
Stock crank in very good cond-75
Stock piston-25
Through shaft-30
Trans gear-75
shift drum-35
Counter balance-30
Flywheel-45
One way brg-45
Driven clutch-125
Wet clutch-85
wet clutch drum shaft and cover-75
Oil cooler adapter with lines-35
Starter-55
Half case were middlemdrive gear broke-make offer
Im sure there is other stuff just ask
Stator-75
oil pump-35
Stock piston-25
Through shaft-30
Trans gear-75
shift drum-35
Counter balance-30
Flywheel-45
One way brg-45
Driven clutch-125
Wet clutch-85
Starter-55
