i had replaced the one way bearing and installed greaseless weights,also 1mm shim.The primary clutch spring is upgraded to orange one or the one up from the duner kit.Reinstalled clutch w/washers in correct places via my manual.Used a impact wrench instead of a torque wrench to tighten 22mm nut up.Making sure the washer covered splines before doing so. this is the second time i have stripped splines on the fixed sheave,am i doing something wrong?
Is it possible the needle bearings under the spindle w/slines are bad?Would anyone know if the bearing in the spider cage(the outer piece that holds the end of the splined piece)can go bad? If,so can the bearing be replaced or do i have to replace the whole cage?
Sorry about my technical terms probablly not correct.Any info would be helpfull please can some one help w/this problem?
Thanks for your time
