HI I am pretty new here.
I just bought my second 660, and before I take it down to my place in Mexico I am doing a few upgrades here at home where I have more tools.
I discovered this Monoprice storage box that fits well under the hood.
you can get it through the Monoprice website but I bought it on Amazon:
I placed the box in the space behind the radiator a bit back to leave room for the oil lines and not crowd the radiator.
I marked the angle of the support bars on the side of the box with a grease pencil.
I took two pieces of 3/8" inch bar stock and flattened the ends by grinding.
I drilled 3/8" holes through the outer plastic box support webbing to feed the bars through.
I drilled holes in the flat spots of the bars to pass a 6mm bolt. You may want to go slightly larger on the bar. One of the holes was off-center a little and I ended up having to weld on a washer instead because the metal on one side of the hole was too thin. (sloppy drilling).
I loosened the battery box, removed the inner upper mounting bolt, and wedged the flat spot on the upper support bar I made under the battery box, and fastened the existing bolt through the plastic box, the hole in the upper rod, then into the frame.
I drilled a hole through the bottom of the battery box at the lower corner on the inside, going through to the frame and tapped it for 6mm.
I tapped the existing hole in the frame opposite the battery box mounting hole to 6mm.
I drilled a new hole in the frame across from the lower hole I drilled in the battery box and tapped it to 6mm.
I painted the bars black, then slid them through the holes in the box webbing.
I then mounted the whole shebang in the space.
It is very sturdy and clears everything well. Th
I ground a little of the webbing on the back of the box hinges a little to allow the lid to open up a bit wider—because I had mounted it pretty far back.
The only thing I have not yet tackled is the vent button. I removed it to clear the lower rod. I will grind a little off of it to make it clear so I can pop it back in.
The thing I like about this installation is the minimum modification to the stock Rhino frame. It only required drilling two small holes in the frame and tapping them
-Andrew.
See pict.
-Andrew.
