The rhino has been sitting for a while now. Been busy with work and school. Before it was sitting I removed all the gas. Well the wife decided she wanted to use it to do yard work. So I went out to the shop put gas in it and messed with it for a bit. Finally got it to crank over and start. It was idling and I walked up to the house to get the keys to the tractor. I heard it quit running. Didn't sound like it sputtered or anything. Just quit running. I went back down there and tried to start it again and nothing. It will turn over. I pulled the spark plug and it has spark. I can hear the fuel pump run when I turn the key or stop trying to crank it. All the fuses seem to be good. Not sure where to go from here. I need to replace the air filter. I took it out before I cranked it the first time. I'm thinking of trying a new spark plug. Any ideas why it would idle for about 3 minutes then die and not start again. I tried spraying starting fluid in the airbox under the hood. It just wants to continously turn over. Really doesn't even try to start. Any help would be appreciated. Thanks
