My 2008 Rhino 450 use to start in gear if I put my foot on the brake pedal, now it does not...
Perhaps a coincidence but brake lights went out about the same time.
I found a switch which is activated by depressing the brake pedal however neither issue is resolved by adjusting it..? What is that switch and or how do I correct these issues?
Thanks in advance for any help and or suggestions!
Have you checked that the switch is getting power? You need to resolve the brake light issue and that in turn will solve the starting problem. I’d be testing the brake light circuit, fuse, and trying to find where the break in power is.
also do not miss the point that the switch can 'freeze' in its position due to all the grunge. Spray with some penetrating lube and exercise it before you start looking elsewhere .
