I found my front differential leaking after a little inspection I found holes in the aluminum. After I tore everything apart the only damage inside is one tooth on one spider gear is missing. I am trying to find a used front diff. I have repaired the hole in the aluminum hosing and cleaned all the shavings from inside the diff. My question is can I run this diff with a tooth missing off the spider gear until I can replace it. Everything seems to be ok other than the tooth that is missing. What do you guys think will happen. It is a 08 700 fi
Administrator
You can run it in lock, but get it fixed asap ....the locked front is suggested ONLY for real low speeds, like rock climbing and occasional high-speed blasts...and like the Llamahead said __you will get tired of fighting the steering wheel
