1 - 15 of 15 Posts
What is everyone running for a spark plug? I'm still on my original plug after 4500 miles. Still runs good. Thought it might be time to upgrade the spark plug. Any suggestions? Thanks
I've been running NGK Iridium in mine for a couple of years now after reading about it on this forum. Seems to start better especially in cold weather.
NGK Iridium...definitely starts quicker if nothing else. NAPA was the only parts store around here that keeps them in stock.
Is there now a Iridium plug for the 700?
Here's the 700 NGK Iridium plug info,,,,CPR7EAIX-9. Good luck.
Thanks USAF-Now the hunt is on to get it local! I have the same engine setup you do-Did you notice any improvement other than starting? Thanks
I really can't say that I noticed any other improvement...just quicker starting which is nice. I have about 2000 miles on it so far and all is well. I carry a spare though just in case...and a spare belt!
anyone have the number for the 07 660? thanks
Another thread on here lists it as follows: DPR8EIX-9...says he got it at Kragen (O'reileys)..NAPA should have it. Good luck.
The post said this is the NGK Iridium Plug for the Rhino 660. I believe all the Rhino 660's call for the same Plug. He has a 07 660. You can type in "Iridium Plugs" in the search block on this forum and it will give you lots of Plug info. That's how I found this info. Good Luck.
1 - 15 of 15 Posts
