1 - 11 of 11 Posts
Hi all. This is my first post so bear with me. I purchased a second hand so cal long travel kit, I can't get the front spindel to fit the lower a arms. Dose anyone know we're I can get the correct spindle kit to fit the stock spindles to the lower a arms. Thanks tom
I have the same kit on mine. Are you looking for the machined washers that fill in for where the stock ball joint went?
Discussion Starter #4
Thanks for the quick replys guys. Yep I am. I don't really know what is suppose to be there instead of the stock ball joint. I have the two bushes that go in to the uniball joint on the a arm . Do you know were I could find some .
I am pretty sure they are custom machined part, however I know other kits use them. One that I recall was Twisted Labs, and I am not sure if they are still in business. About all you can do is check with several of the long travel manufacturers and see if they use a uni ball. If they do, then you should be able to use their bushings.
you need to get a hold of Thad. He was the one that built that kit. He has a new company Fabwerx or something like that. He should be able to get the parts you need.
Twisted labs has what you are after:
Spindle Adapter-Lower
Twisted labs is no longer making kits but the site is still up and accepting orders for those who have their kits and need replacement stuff. I just bought a couple tie rods from here two weeks ago and the parts showed up at my door 3 bus days later.
Hey I know it's an old thread but I have an 07 rhino with the so cal fab lt kit and broke the stud on the ball joint. I'm pretty sure it's the uniball you guys are referring to but none of the links are up anymore. If anyone has some advice I'd appreciate it
does one of these look like wat u need?
you can call these guys and give them ur measurements and they might hook u up
1 - 11 of 11 Posts
