Sounds like you might have PDM clutch...
So you know who made it ...
Could be a Bronco... they are also a dry clutch conversion... not as noisy...
You can revert back to the factory wet clutch... MOST people prefer the wet clutch even tho it is not as fast...
It is a dry clutch, all I know is dragonfire built the car and the clutch is whoever they use.
Could be either one then...
Take pics of it and post them and someone will be able to tell you which one you have...
Anyway...that is your option... if you already have Bronco and want quieter with cover you have to convert back to wet clutch...
You might want to check with for oem clutch parts and info on that...
Thanks for info. Have always had teryx's and this is the first rhino (family) ive owned. Hopefully he will see this and just post..
