Just bought a 2004 660 Rinho has a 6 inch gorilla lift and axles running 31x14 outlaws. Have problems shifting tranny unless kill engine then shift. What work or clutch recommended?
Thanks
If the idle jumps up you might look for an air leak in carb joints and IIRC also the mixture screw. From my experience with 660s, there is a fine point where the single cylinder needs to idle and then starts to fall off and surge. Check manual but think it around 1600 rpm, I have a $24 little digital tach you can wrap a wire around spark plug wire to get the accurate rpm which is very helpful.
