I installed a Hotrod sheave a couple weeks ago and ended up losing a little on the top end. I talked to James and he said to check and make sure none of the weights moved when I installed it.
Well I pulled it off today and everything is okay, but I did find a washer/spacer on the back side of the collar. Is there supposed to be one there?
It had a machined sheave when I bought the Rhino so I am wondering if I should put it back together without the washer.
I put a call into James and waiting for a call back, so I thought I would check with you guys here in the mean time.
Thanks for any help!
Rick
Rick
