belt started to smoke. so headed back to the truck. this machine is new to me. when opened the belt cover. first i see the vent hose has warped to unusable from heat. in the case was the little horseshoe sheave parts and a destroyed belt. pulled sheave off weights are there and grease is burnt on to it like a rock. further in, the other sheave half has no splines left in it. and the half has been spinning and damaged the clutch casing slightly. clutch is in good condition. i will post some pics. what im looking for is if anyone has been down this road also any advice. i have ordered all parts from partzilla that have been damaged. except the vent hose thinking of building my own for it.
65028
65029
65030
65031
65032
65033
Call Hunterworks and get you a new machined sheave ... you will need to get the inner stationary part too, because it does not come with the clutch.
