Put a short hose on the brake fluid bleed nipple, stick the loose end of the hose into a container and crack the valve open a bit while pressing the caliper piston in. That will ensure that the fluid within the cylinder has a place to go. Close off the valve as soon as you have the piston retracted, in order to minimize the need for bleeding of the brake line after you are done.The brake lines are still hook up to the rear brake calipers. I used a large Channel Pliers to draw the cylinder into the caliper and it will not move.
Links should work now. Tinken also has the link in his signature.For some reason i can't get the 660 Service Manual to work, what am I doing wrong. Any help would be helpful?
