I thought I sent a PM twice, but I don't think I did. Do you have to have a paid subscription to PM somebody?
Administrator
No paid subscription is necessary, but just being logged in will give you PM rights....
Let's test this....send me a PM and reply back here right after you do it.....Cool?? That way we'll know what the problem may be if not working properly.
PM sent to you, please reply back...thanx.
Hi I'm new here. I have a 450 rhino, not running strong anymore. Changed the plug, fuel pump and filter, also the carb. Sounds better, still not running anywhere as fast as it did. Cuts out at full throttle going downhill. I suspect it might be the valves but have no clue how to adjust them.
Yes it will but you should post your threads in the proper sections of the forums. If u use a computer to view the site u can download a manual from a member on here called tinken. The different sized rhinos are listed under his signature
