1 - 9 of 9 Posts
Is there truly a product that takes scraches out of a plastic winsheld? If so whats the name and where do you buy it? THANKS!!!!!!
some automotive polish and a buffer will get those out.
Plexus and Lemon Pledge work pretty good at covering up scratches in all types of plastics used in windshields. However be advised if you have hard coating like MR10 or others a buffer can and probably will burn the coating leaving you with a dark spot, worse than a scratch IMO.
If you have un-coated Acrylic (plexiglass) then it will buff out ok as long as it doesn't get too hot in the process.
Thanks ;Joe for the info it worked great! Walker61 southern Ohio
1 - 9 of 9 Posts
