1 - 2 of 2 Posts
I've got an 09 rhino 700 that has recently started running over 15 volts while under load. I also started having over heating issues at the same time. I saw another post that said the bearing being messed up in my cooling fan (which it was) could possibly cause the issue with the voltage. Ive got a new cooling fan on it today and when I put some throttle to it it shot up to 15 volts which is less than it was running. Is there something else I need to check? I have replaced both the stator and voltage regulator since I've owned it.
I'd start by getting out my voltage meter to confirm the digital display reading is accurate. Then I'd test both stator and rectifier/regulator.
1 - 2 of 2 Posts
