1 - 13 of 13 Posts
WOOOOOT!!
We have about 6 of these left in stock!!
Retail: $349.98
RhinoCrap.com Price for RhinoForums.net members - $329.95 !!
Enter Coupon Code - RFNETEXHAUST at check out to recieve DISCOUNT!!
Add one of our V.A.L.E slip-on exhaust systems and turn on the power. Custom designed for the 2004-2007 Rhino 660, you'll see both torque and horsepower increases over the OEM system.
OEM Exhaust System......................... 10.5 lbs
Two Brothers Exhaust System............ 6.4 lbs
I have the dual Two Bros on my 07. I can tell you it's fairly loud but I hear it's not as loud as the Dragon Fire. Not sure if it's louder than the single set up but it really sounds good. I didn't even know they offered a single Two Bros. til I saw this thread.
it doesn't give you that much more...but the dual does sound mean.
I dont know how load the 2 bros is but i can tell you the dfr. duels are very load.
Got a few of questions about the two bros single.
1. How much louder then stock
2. Can you feel a difference in the performance.
3. Do you have to rejet or something else along with it.
4. Does it void my Y.E.S warranty.
Any input would be really appreciated. Because I need start working on a order.
Discussion Starter · #11 ·
It is louder than stock but only by a few decibles, not annoying or anythng close to the duals.
TwoBros says its a 2+ hp increase, I personally have yet to run one or install one.
The exhaust was designed using a STOCK rhino, so if your rhino is STOCK minus the CDI and this exhaust, you dont have to rejet. Any time you do any intake or carb mods, rejetting is a must and HUGE plus!
Does not void your warranty according to TwoBros
Thanks for the reply you covered all the info I needed. I got one more question. Should I wait till I do my first 20 hours before I get?
1 - 13 of 13 Posts
