1 - 10 of 10 Posts
Nice work looks like a nice setup.
I am thinking about buying this, but I am curious about the durability of them... I know most of us ride our bikes pretty hard, so I just don't know how well they'll take the punishment...
This kit is used in addition to the shocks that are already on your Rhino so they dont take all the abuse. I only have 1 season (about 60hrs) on my kit with no problems so I cant say much beyond that. Only possible issue would be if you run them without any pressure the rubber inside can abrade itself. So as long as there is a min of 20psi they should last many many years.
The metal brackets are 3/16 which is much thicker than the factory steel and all the bolts are Grade 5 and all nuts are nylocs.
The shocks do provide some compression and rebound dampening which also makes it ride and handle better. Obviously not for racing but a huge improvement over stock especially on 4 seaters and being able to adjust the psi makes this a great option.
1 - 10 of 10 Posts
