My rhino is slow taking off like something is slipping but about 3 to 4mph it accelerates fine, after take off no slip at all. It is only at take off.I pulled the primary sheeve and cleaned all the grease out, found some of the weights worn with flat spots, went with hunter works greaseless weights and sliders. Both the primary and secondary clutches are working correctly. The belt is just under 32mm, I have pulled the wet clutch assembly and found the clutch shoes to be in good shape with mild wear, still above spec. The one way bearing appears to be working correctly. Any thoughts would be appreciated. thanks
