I have a 2007 rhino sport, if your looking from the back of the rhino it leans to the left(driver side). How do I adjust the shock to stop the sag to the left? Do they need to be replaced? if so where can I send them. Shocks look good no fluid loss.
thanks in advance.
Start with adding some pre load on that side by cranking the adjustable collars down to push off the spring more. If it’s not too bad “sag” that should be a cheap easy fix
Super Lead Moderator
If it needs a rebuild try ishock.com
